DJI offers no process to unregister drones.Do I have to un-register from DJI?
True (for people in the US). The OP is asking about registering the drone in DJI GO though.If I’m not mistaken the P4 should have been registered with the FAA regardless of operations
If you register with the FAA as a recreational pilot, you're not registering the drone with serial number. You're actually registering yourself as a pilot and you're required to put your registration number on all of your craft. You're required to adhere that number to the drone in a place that requires no tools to see it, such as inside the battery compartment, or on a battery surface hidden inside. If you sell a craft, simply remove the pilot's registration number and you're good.If I’m not mistaken the P4 should have been registered with the FAA regardless of operations within the guidelines of 14CFR 107 operations or not. I would consult the regulation for your exact answer. If you never complied with the reg, no worries.
