Software update
Hi
I'm in the process of updating my P4 software, I haven't done this since Christmas as I've not used the drone, it got to 99% about 15 minutes ago and instructed me to unplug & reply the cable, it's still on 99%. The light on the remote is flashing red / green, the little light on the aircraft (above the cable socket) is solid green. The whole process has been running for about 30 minutes now. Is this right or has something gone wrong and what should I do?
The firmware should be installed. Restart your Phantom and check the version number in the "General Settings" --> "About" section of DJI GO.
It also seems I have to do this for each battery - is that right?
DJI GO will prompt you to update the battery firmware if needed. Each battery needs to be updated separately. If you don't see a prompt, then the current battery does not need to be updated.
akinproplumbing
