Nothing so special other the tab holder.
Hi Teds quichen where did you get the tablet holder from?
Cheers
Adrian
I hope you have a strong back, carrying that must be a fair old weightMade this mod (P3 4K), not tested yet. Btw I changed back the internal cables to the thin ones. Somehow the RG178 RPSMA cable (thick one) is not good for my internal cable. Lose the signal faster than the thin ones.View attachment 67942
That's why I also bought the tripod mount for evolite.I hope you have a strong back, carrying that must be a fair old weight
Let me know if you can't open it. It's still in the listing.
SMA male to RP-SMA male both right angle RF lot RG402 Semi Flexible blue Cable | eBay
Check this: Coaxial Cable Specifications Cables Chart - RF CafeThx link works and i found the seller on ebay ;-)
What is the diff between RG58 and RG402 ? Which one is better ?
Cheers
Looks like the 402 has less signal loss.
The column I'm looking at the one that says DB/100 ft @400 MHz. That should be the signal loss per 100'@400 MHz. Now that's not the frequently we use with our drones but it's just a frame of reference at that given frequency. So therefore lower numbers are better in that column, also keep in mind we're only using a few inches worth of any given cable.
That's what I use, here's a pic before the amps were added.ok Thx wmcvey. yeah i know we use small distance cable. if 402 are better and as i can find what i need more easely on ebay i will go with them![]()
