show: first try with making a map - P4P Pro v2.0 - 245 images, 56 acres, 360 ft high
You will learn things in every mapping flight you do. There is always something that you will want to tweak next time. Camera settings can have a lot to do with the quality of your mapping results. My "go to" settings are setting to shutter control, ISO set at 100, a manual white balance setting of 5800 on sunny days. Stay away from auto settings, because you normally don't want your camera adjusting to lighting conditions during a single mapping mission. Overlap is important and can be 70-90% front and side. But the higher the side overlap, the longer your mission. Make sure to set P4P to mechanical shutter. At 250ft altitude, I get good results flying at 10 mph. Your results may vary, so just keep testing different settings. There is no magic setting(s) that works for all conditions.
Reactions: tayl0r
fredkamphues
