Sharing is caring!
cougar said:
FearOfTheDark said:
get a used Makerbot Replicator 2 - best **** out here right now!
Thank you, will check it out.
Have been looking around for a good 3d printer but since I am new to this might need some advice.
Do I need special files for different printers?
Found this printer FLASHFORGE Dreamer Dual Extrusion 3D Printer. looks very promising to me, any comments?
Thank you for any help/input
Other than the build volume being a bit small it looks like a good deal (for a dual extruder printer). They say it prints ABS, but no mention of heated build plate? You might want to look into max temperatures of the filament extruder, since Taulman nylon 618 / 645, T-Glase etc. require higher extruder temperatures.
I use a Solidoodle 4 myself.
Thank you for any help/input[/quote]
I use a Solidoodle 4 myself.[/quote]
Thank you for the quick response, any concerns regarding files? I am using a MAC.
Here is the specifications that I found:
Printing material: 1.75mm ABS or PLA
Print Technology: FUSED FILAMENT FABRICATION
Printer dimensions: 485 x 400 x 335 mm
Build volume: 230 x 150 x 150 mm
Layer thickness: 0.1-0.5mm
Number of Extruders: 2
Nozzle diameter: 0.4mm
Heated Build Platform: 120 C Maximum
Extrusion temperature: Recommended Maximum 230 C
AC Input: AC100-240V, 50/60Hz 300W
Connectivity: SD card or over USB
File formats accepted: stl
Printer software: FlashPrint
OS Compatibility: Linux, OSX, and Windows
OS Compatibility: Linux, OSX, and Windows[/quote]
Files should not be an issue. Most printers accept STL files, that is, convert STL files to gcode, which is the code the printer actually prints. Have a look at slic3r.org to learn more about gcode :)
Ship date was extended with no notice. No guesses from seller as to ship date. We cancelled the order. Nice people, but flaky business model.
rockymountaincaptures
