http://www.shapeways.com/model/1041193/ ... r-kit.html
It works well, but operate with care. The + profile at the end of the rod that goes in the pot meter is rather weak. I had the rod rotating freely after reaching one of the extremes, and thought it was the screw coming loose. So rotated the other way, and applied some, but really not much pressure to get good control again. This happened a few times; and today the + profile broke off, leaving me with a useless flat surfaced rod, and the + profile stuck in the pot meter. I got the profile out easy enough, but I might have to order a new set :|
So if you have it, operate with care; take your time and open the tx up if you want to adjust things or you loose money and time :idea:
