Re: Setting up the Futaba T8FGS with the P2
Yep. The circuit board was hanging on tooth and nail and I realized I didn't have to force it. Just slid the rocker under, hooked the spring on the end and drew it up with a pair of tweezers. I already had all the screws out so I had to put them back. Would have taken almost no time if I hadn't partially disassembled it.
The mod is nice, though. I set the tension the same as the roll/pitch (screw almost all the way down) and it seems perfect. It is now cold again but I'm anxious to try it all out.
OBTW: If anyone has a link to where I can get the 400 mm extensions for the rx, I would appreciate it. I can't find it using my normal Google foo. MIght call support on Monday if no joy.
EDIT: No more than wrote the above but found a method of getting the antenna extensions (disregard the 'boat only' caveat):
You can order these directly through your local authorized Great Planes hobby store, or from our Futaba Support line at 217-398-8970. The part number and suggested retail price is:
HSP79766 ANT BOAT ONLY 400MM $12.13
Dtacmed said:Simular to the 8J however sliding out the entire gimbal was a pain. I agree slide it under instead of removing the entire gimbal. There is a circuit board on the outside of the gimbal that I found was a pain to get out and back in.
