Saving camera settings
We are manually setting the camera / gimbal settings but they don't seem to change. There are 3 different (can't remember exact name) themes where you can adjust gimbal speed and camera settings etc but one you have set theme 1, you go to change theme 2 and all the numbers in theme 1 change to whatever you are entering for theme 2! Frustratin!
JustGo,
It is a little glitchy, but I think it is working.
I started in auto
Created a manual setting
Gave it a name "Special xxxx"
Saved it
Tested, here is what I got:
I again started in auto, then went to the custom screen and I could see the "Special xxxx". I selected it, prompted for load, and here is where it got a bit odd, it changed the setting as expected then it displayed the name "custom 1" vs my save name, then within a few moments it reverted back to my saved name. It also goes back to custom if the drone is shut down. Here are the picture in the order it was displayed to me.
I hope this helps.
After giving it a little more thought, I think it reverts to custom 1 for a moment because the camera is restarting during the load, and if the camera is not on then the defaults only show.
Note the 3rd picture shows no signal at the top. This was the restart.
That's my best guess anyway.
robvalduga
