Sample Test Questions for Unmanned Pilot Cert
so we will need to know this...
PLT130 Recall aircraft performance - fuel PLT131 Recall aircraft performance - ground effect PLT132 Recall aircraft performance - instrument markings / airspeed / definitions / indications PLT133 Recall aircraft performance - normal climb / descent rates PLT134 Recall aircraft performance - takeoff PLT135 Recall aircraft pressurization - system / operation PLT136 Recall aircraft systems - anti-icing / deicing PLT137 Recall aircraft systems - environmental control PLT138 Recall aircraft landing gear/tires - types / characteristics PLT139 Recall aircraft warning systems - stall / fire / retractable gear / terrain awareness PLT140 Recall airport operations - LAHSO PLT141 Recall airport operations - markings / signs / lighting PLT142 Recall airport operations - noise avoidance routes PLT143 Recall airport operations - rescue / fire fighting vehicles and types of agents PLT144 Recall airport operations - runway conditions PLT145 Recall airport operations - runway lighting PLT146 Recall airport operations - traffic pattern procedures / communication procedures PLT147 Recall airport operations - visual glideslope indicators PLT148 Recall airport operations lighting - MALS / ALSF / RCLS / TDZL PLT149 Recall airport preflight / taxi operations - procedures PLT150 Recall airport traffic patterns - entry procedures PLT151 Recall airship - buoyancy PLT152 Recall airship - flight characteristics / controllability PLT153 Recall airship - flight operations PLT154 Recall airship - ground weigh-off / static / trim condition PLT155 Recall airship - maintaining pressure PLT156 Recall airship - maximum headway / flight at equilibrium PLT157 Recall airship - pressure height / dampers / position PLT158 Recall airship - pressure height / manometers PLT159 Recall airship - pressure height / super heat / valving gas PLT160 Recall airship - stability / control / positive superheat PLT161 Recall airspace classes - limits / requirements / restrictions / airspeeds / equipment PLT162 Recall airspace requirements - operations PLT163 Recall airspace requirements - visibility / cloud clearance PLT164 Recall airspeed - effects during a turn PLT165 Recall altimeter - effect of temperature changes PLT166 Recall altimeter - settings / setting procedures PLT167 Recall altimeters - characteristics / accuracy PLT168 Recall angle of attack - characteristics / forces / principles PLT169 Recall antitorque system - components / functions PLT170 Recall approach / landing / taxiing techniques
5
Wow. So much information that's way over my head...
That list is hyperbole.
Not all of those areas will apply to UAS. You can see the sections below the answers.
Well when you look at the reported drone accidents we read about there doesn't appear to be a lot of common sense exhibited by those involved.
Reactions: flpholt
Common sense? I downloaded this free iOS app, and was rather surprised how many answers I was getting an X on. Study time?
  1. Trivia Drone on the App Store - itunes.apple.com
    itunes.apple.com/us/app/trivia-drone/id1077629444?mt=8
    Do you Consider yourself a Drone Pilot expert? Trivia Drone is the game for you! Trivia Drone is a fun ...
RedHotPoker
Reactions: Traveler
DonT
