RTK/PPK Drone Mapping
Austin, Texas
Good morning all! I have been signed up for a little while, but fairly new to using this forum and wanted to see what kind of mapping presence there was. Who is using their drones for survey-grade mapping and if you are using RTK/PPK, what's your setup?
We operate two DJI Phantom 4 Pro's and two Yuneec H520's. All with Emlid PPK systems consisting of an RS+ base, M+ drone and AShot camera shot trigger capture. We use RTKLIB for post-processing, DroneDeploy and Metashape for map processing, Carlson Precision 3D for point cloud management and Carlson Civil with Civil 3D for integration and analysis.
Thanks in advance!
Good afternoon
We use our drones for survey mapping: Phantom 2 with Gopro Hero 4, Phantom 4 Pro V2.0 and Inspire 1. We use groundcontrol points and as software Pix4dmapper.
Just at the moment we are evaulating ARGONAUT from Rokubun to reduce the workflow in the field for the ground conrol points.
best regards
Reactions: chascoadmin
Good afternoon
best regards
Are you thinking of using The Argonaut as some sort of propeller aeropoint-style ground control point?
