- Joined
- Mar 10, 2017
- Messages
- 467
- Reaction score
- 109
- Age
- 63
It is well proven that 10ms is somewhere around 40% below the airspeed that provides greatest flight distance on the phantom 3 series and we have no reason to suspect the P4 might be significantly different.It doesn't normally use full power, normally 10m/s on the P4P too. I think part of the reasoning for this is to use a speed that is more battery efficient, and a speed that collision avoidance works on. Although it does look like it tries to do 10m/s ground speed, not airspeed, so in high headwinds may use near full power to achieve that. You can use the stick to speed things up, but as others have said, a headwind on RTH can make for dicey returns.
Which is 22mph right? Cool! So you think P4P would be the same at that right?It is well proven that 10ms is somewhere around 40% below the airspeed that provides greatest flight distance on the phantom 3 series and we have no reason to suspect the P4 might be significantly different.
22mph is just shy of 10ms. I understand the P4 is the same however only going by what I have read, I haven't tested it.Which is 22mph right? Cool! So you think P4P would be the same at that right?
10 m/s is very battery inefficient and you'll go much further at 13-14 m/s.I think part of the reasoning for this is to use a speed that is more battery efficient, and a speed that collision avoidance works on.
Just don't ever forget returning in headwinds that are strong. Because that speed is also about cut in half. Heard over 100 times of people flying out with a tailwind really far and not making it back because they didn't take into account the returning headwind speeds. I know this isn't answering your question but just a friendly reminder to not forget.
Here's the best thread on speed/distance efficiency: Best fuel efficiency testsDoes anyone have a link to a chart on this information? I'd like to understand it.
