Rotorpixel installation
I could use some help in figuring out how to remove the "the small hard plastic servo transmission block from inside the ear". This is step number 9 in the instructions. I am not even sure what this is although I think it's the white plastic "thing" attached between the ears on the camera. Any help in how to get this thing off would be appreciated. Is there a video?
Thanks Robert
Pull_Up posted a video when he installed his. That may help you.
[youtube]http://www.youtube.com/watch?v=w1njtavc0Yo[/youtube]
Rotate the camera full down to expose the gear slot, use a small flat tip screwdriver on the inside of the ear to press the white spacer outward, about halfway out the camera will just drop into your hand.
Once the camera is off the gimbal you will be able to push the white spacer out of the camera ear from the inside.
Thanks guys! I watchd pull up's video and it helped. Then I got my wife to actually do it while I supervised :D
