Remote unit
Hello. My remote unit, when turned on, it starts @ green, than turns red.
I changed the batteries, and that is still happening. Any suggestions?
Thank you all very much!
John
Check the contacts in the RC especially the end where the positive part of the battery make contact. Even a light sanding with sandpaper or crocus cloth will help make good contact. As a minimum you can use electrical contact cleaner.
Red indicates low battery. If these are new clean fresh batteries then has to be the contacts or a hardware issue. Try contacts first.
fiweli
