Quiver in video when filming???
I have the slighest quiver, shake, movement when watching my videos from my Phantom 4.
It is minor BUT enough to see while watching. It is mostly while stationary in the air and while flying I can not detech the quiver.
I am using an ND 8 filter, have the shutter set to 50 and filming at 24 fps.
Also no to little wind.
Is this normal if not what can I do to correct it?
Does the Phantom 4Pro do this also?
RC
Is it possible you have a damaged prop? Maybe a small chip or something throwing off the balance?
Well check that. Only have about 5 flights on it.
After reading other post I found the foam behind the camera and removed it. Maybe this will help.
Can't fly now due to rain.
RC
In the future it would be a benefit to insure that it has nothing to do with the Video playback software. Record a short sequence using the same record parameters while the Phantom is sitting on a picnic table with the motors off.
Michello
