Question about prop reaming?
I picked up some APC Slo-Flyer 9x4.7 props to try out.
Clearly I need to use a reamer to to get the to 8mm for my stock motors. So do I simply disregard the flat sides of the motor shaft and just rely on the prop nut to lock them down safely to the motors?
MX45OR said:
Yes, then tighten down tighter than stock. Carbon?
You can also use a .315" reamer. ;)
Cheapo plastic.
viewimage.php
The APC props are great! requiring almost no balancing!
(i've been flying with the 8x3.8, pondering trying out the 4.7's,. . tho my Phantom is heavy so I dunno).
But I used these fiber washers underneath my props (between prop and motor) to add some height
available at serious hardware stores, such as True value
http://wedo.hillmangroup.com/item/rubbe ... ers/3819-k
Hah, serious stores... Yeah, they were pretty close, I used the scotch tape trick to get them perfect. The 9" just clears the hull, so I think that's it. Will have a test flight tomorrow and report back.
