Puzzled
After working on my P3a for several after a crash , fixing several problems and installing new ribbon cable, fixing camera motor overheating, I finally started to get video feed, but only if I hold the copter on the side, if I put it level I will lose signal, even moving it very gently in all positions, as you move upright the video will lag and lose it all together as you bring it level, put on side again video feed is fine again. has anyone had this issue. the camera motor issue overheating was caused by the ribbon cable , where it comes out of the camera starting the first wrap the adhesive did not adhere where it should causing the cable to bind.
Jerry P
