Purple lines in Videos & Pictures when using my P3P
Updated app today and still got the same issue.
But I have now ruled out a ribbon fault.
As when I chance the while balance to less then 5000k the lines go away.
Got the lines back & it's a lot worst.
Now does it with ND filter on.
Seems to go ok after the phantom been on 5-10 minutes.
When it started working today.
I give the whole drone a shake but all stays good once working.
Is this a part in the camera I can replace or do I have to replace the whole camera ?
Also what is the price of this part ?
I replaced both small harnesses and the flat ribbon cable after doing hours upon hours of diagnosing.
Something to keep in mind is, you're not dealing with just 1 wire but multiple wires. And each one of those small wires has it's own dedicated function it's responsible for. A breakage in any part and or short can play havoc.
flyNfrank, Did you have the same issue as me ?
Am thinking of buying a working used camera from ebay and replace myself.
Bad CMOS sensor,
Do I need to replace the whole camera or is the a part I can order or take off a camera with a different issue?
In my case it was a faulty canera, replaced under warranty (P3P).
The lines apprared as acattered random purple however when i zoomed in it was obvious that while parts of the image.had been shifted elsewhere in the image.
Yeah, I had one that DJI replaced that was exhibiting the same issue, purple bands in the recorded video.
Edit: DJI sent me a brand new craft (back in the days when support moved their facilities), so I have no idea exactly what part caused the issue.
Your issue is unlike any that I have had. I would guess what you are seeing in the video would be somehow related to the microSD card. I say that because the actual visual quality does not seem to suffer in any way, other then the lines mentioned.
