Purple lines in Videos & Pictures when using my P3P
Discussion in 'Pro/Adv Discussion' started by Speedy-UK, Feb 21, 2016.
  1. Speedy-UK
    Not all the time but sometimes my P3P recodings have about 10 - 20 purple lines running down the screen,
    I also see this on my hudl 2 tablet & Phone 6S live feed as well as when watching back via the SD in my laptop.
    Am thinking its a faulty camera ribbon issue.
    Am I best changing the ribbon? is this an easy task ?
  2. DroneDestination
    Do you have Over Exposure Warning on?
  3. Speedy-UK
    Is that the setting that puts black bars over exposed areas.
    If so yes this is off.
    #3 Speedy-UK, Feb 21, 2016
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Yes -- the zebra stripes.
    Try using a different memory card. If you see the same issue at that point, then the cables are most likely the cause of the problem. They might just be loose.
  5. Speedy-UK
    I have 3 x 32gb SD cards, 80mbps Speed.
    Had same issue on all of them.
    I will try pushing in ribbon connections.
    Thanks.
  6. Oso
    Oso
    Western US
    Since you said you still see the issues when viewing the videos from your SD card, the over exposure zebra stripes are not the issue. Not to mention "10-20 purple lines running down the screen" doesn't sound like the zebra stripes anyway.
    I would also think cables first and I would first try unplugging them and plugging them back in before looking anywhere else.
    Please keep us updated. Good luck!
  7. Speedy-UK
    Will give this ago tomorrow. Thank you.
  8. Speedy-UK
    I reconnected the ribbon ends and still got the issue.
    I have now noticed the lines seems to only show when the camera is pointing towards the sun.
    So today Installed a ND 16 filter and when out flying & I did not get any issues with the purple lines.
    (40 minutes flying)
    Am now thinking I only get the issue when the ISO is very high.
    Anyone have a clue why ?
  9. With The Birds
    Australia
    In my case it was a faulty canera, replaced under warranty (P3P).
    The lines apprared as acattered random purple however when i zoomed in it was obvious that while parts of the image.had been shifted elsewhere in the image.
  10. Speedy-UK
    Could my camera be faulty ?
  11. With The Birds
    Australia
    Could be. Writing images with what sounds like simillar problems to what i had on multiple sd cards. In my case it was a faulty camera.
  12. Tim_alabim
    If only when facing the sun, it sounds like prop shadows.
  13. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Prop shadows are always horizontal though. The OP mentioned running "down the screen", so I'm assuming that means these lines are vertical.
  14. Speedy-UK
    Will add a picture later.
    Not seen since using ND16 filter.
  15. Speedy-UK
    [​IMG]
  16. Speedy-UK
    All OK with ND16 but anything less lines comes back.
    Also seems to be getting worse, as you can see in the picture above.
  17. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Speedy-UK, try a different memory card. If that does not fix it, ensure the gimbal cables are fully inserted.
  18. Speedy-UK
    I have tried a few SD cards.
    Might need a new ribbon cable.
    An if it's the camera am not sure if I'll be coved by DJI as I got my P3P from a supply on eBay that's no longer trading.
  19. L.Chaney
    I fixed mine I hope. I started fiddling around with the firmware and got things to where there were no more lines.
    App version 2.6.0
    Aircraft 1.4.10+
    RC 1.3.20
    Not that it will work for you but I no longer have that purple gorilla on my back.
    Woot
  20. Speedy-UK
    Just thinking did I get the lines after an update.
    But there been a few updates so can't remember.
Similar Threads - Purple lines Videos Forum Date
Purple lines in Videos & Pictures when using my P3P Pro/Adv Discussion Jun 6, 2016
Purple lines with my android tablet Pro/Adv Discussion Apr 12, 2017
Advanced Purple and blue scrambled lines on video app Phantom 3 Help Dec 3, 2016
Purple lines on DNG raw files Phantom 4 Help Nov 13, 2016
Purple lines General Discussion Oct 4, 2016
