Re: Purchased the Moverio BT-200 Smart Glasses? Review & Hel
While its true you can't run the vision app on the glasses AND cast it to another device, as the moverio are lacking the necessary hardware to establish two WiFi links, they can also work as a mirrorcast sink device which means you CAN run the dji app on another device, I use a nexus 5 but any phone tablet with the capable WiFi hardware will work fine, and cast that screen to the moverios which does enable one person to get the nice big floating screen showing live video while someone else can watch on the phone / tablet. There is approx 1/4 second delay on the feed cast to the moverio which is barely noticeable at all.
I use mine as above when doing missions as attempting to enter a mission on the moverio touchpad is a nightmare.
These glasses do have their limitations but let's keep the info on this thread genuine and real instead of based on rumour or assumptions [emoji1]
Anker battery packs (i have the 15000 mAh with dual usb connection) certainly provide external power capable of charging the moverios, I use mine all the time.Dillinger said:on early post I unserstood, that USB charging IS NOT working. Moverio manual tells anything about it, only AC power charging is sure.
Pretty useless on roadtrip, then.
And no way to share videofeed to someone next to You, for example - put glasses to someones head and fly Yourself vision to give idea what FPV is. Did anyone tried this with Cinemizers? Iphone hdmi and videofeed in glasses should do the trick?
Wifi video feeding is also not an option, two wifi connections are ruling out this? FPV is not still there.
