Propeller blades
Discussion in 'Pro/Adv Discussion' started by Fatcat1, Feb 28, 2016.
  1. Fatcat1
    Texas
    Has anyone used these before would like some other P3P owners to tell me if they use these are not[​IMG]
  2. Monte55
    Raymore Missouri
    Did you buy them used?
  3. Dirty Bird
    Glen Burnie, MD - USA
    Personally I would not recommend those. Tri/quad blades are less efficient than the stock twin-bladed props. You will likely experience significantly reduced flight times and who knows what in terms of reliability & performance.
  4. AMC724
    Haslet texas
    Do a search for them, they have been theorized, reviewed, and tested...the results will surprise you!
  5. 185EZ
    #5 185EZ, Feb 28, 2016
  6. ChaneRZ
    GSW, 49ers, SF Giants
    They look cool. Review them please.
  7. 185EZ
    #7 185EZ, Feb 28, 2016
  8. 185EZ
    #8 185EZ, Feb 28, 2016
  9. Meta4
    Meta4 Moderator
    Staff Member
    They're rubbish and thinking that you can just grab any old aftermarket tat that looks cool and do a better job than DJI's propulsion engineers is pretty silly.
    The motors, ESCs and props are a finely matched combination.
    Suntana and 185EZ like this.
  10. syotr
    Generally speaking, more blades equals higher thrust but more drag and less efficiency. Substituting a three bladed prop on the existing motors could overheat them. If you choose a motor designed to match a three bladed prop, they may work OK.
    I have considered using three bladed props on an F550 frame where I have motors which can handle a larger prop but am limited by the distance between motors.
    There are some quads which have made efficient use of small three bladed props such as the Parrot Bebop 2 with 25 minute flight time.
Similar Threads - Propeller blades Forum Date
Any insights for the Propeller with 3 blades for my Phantom 2? General Discussion Jun 7, 2015
Is anyone else using propeller guards on a P4P? Phantom 4 Pro Discussion Today at 12:06 PM
questioning DJI propeller design General Discussion Jan 6, 2018
Advanced Propeller guards Phantom 3 Help Jan 1, 2018
Propeller Is Stuck After Crash ... HELP Phantom SE Dec 28, 2017
