Power Lead Next To Antenna In Landing Gear
Cherry Hill, Southern NJ
Hi All...
I am mounting 2 LED strobes, 1 under each front motor, which will powered by small 2 cell lipo. The wires will run from the battery up the landing gear and go inside out the motor arms. The wires will be touching the antennas. Will they interfere with the antenna and the signal ? Thanks In Advance !
They will not interfere with the antennas, but will screw up the compass.
Thanks HWCM.... I thought (probably incorrect) the compass wire was in the Right Rear leg...that's the leg with 2 wires??
No, only if you run the wires along the leg with the compass.
cokersean20
