To be fair - my Phantom came right from China yesterday and had 1.9 pre-loaded - so I didn't officially upgrade - but have been flying today and have had no issues whatsoever...
Tomorrow I will update firmware on my P3P. I watch some turtorials, but I have one question that I didn't get. When the whole process is finished (with aircraft, transmitter and battery), what to do with .BIN file? Do I need to delete him from Micro SD before first filght or what?
YesTomorrow I will update firmware on my P3P. I watch some turtorials, but I have one question that I didn't get. When the whole process is finished (with aircraft, transmitter and battery), what to do with .BIN file? Do I need to delete him from Micro SD before first filght or what?
Yes, you can delete it if you want. If you leave it in the root folder it wouldn't necessarily do anything wrong. However, since it's an update file the P3 would check the file upon starting and notice that it's the same firmware that is currently installed.
I was running 1.1.2 on my flight I mentioned above using an iPhone 6. Everything worked flawlessly.From what most are reporting around forums, its the latest ios 1.1.2 that is causing problems not the firmware of the craft.
same here no issuesI was running 1.1.2 on my flight I mentioned above using an iPhone 6. Everything worked flawlessly.
Is anyone here using the ipad mini 2 cellular (+ the latest 1.1.9 firmware AND 1.1.2 app) ? - I had huge problems even before the latest firmware, my drone is thus currently back at the dealer.
Just wondered if there is anyone out there with no issues with this particular set up?
Seems mine gets the no signal, disconnect, and past couple days app hang. Tried different channels, transmission rate, nothing seems to fix it consistently. Heck I can turn the unit on and before I take off it will do this. A lot of times I return home with it (push button because remote still works with green light), land unit, turn off and back on. Seems to fix it temporarily. Got a new Anker certified cable coming Tuesday. Its shorter and I hope fixes or alleviates some of these issues. Otherwise I hope it is something simple as a firmware issue.
