(pic inside) P1 version 1.2.1 what is the purpose of this red/gray wire
Not the power wire the small skinny red gray in white glue above currently it's clipped and stuck in shell unused
6cuJdN3
6cuJdN3
Try uploading the pic again, please.
That's an auxillary power supply for an led light or gimbal. Be careful not to let the two ends come in contact, they're hot and will short out. I found that out the hard way, DJI should really just put a balance connector on the ends instead of leaving them bare.
I agree with Woody, if that's what yours looks like.
If you stuffed them up in the hole, they may find a way to short. :(
The OP said they were not powered though. Maybe I misunderstood him.
So then that wire I can use to power a vtx? I'm assuming red is hot and grey is negative right?
Made in China capodrone81, but yea, it should be that way.
Voltmeter cheap, repairs expensive.
