Phantom3 Pro with standard controller
I have just purchased a phantom 3 pro (second hand but barely used). The controller only has a micro USB, so following other threads it appears to be similar to the standard controller. I have had to connect using wifi. Not a problem, but I am wondering what I have got? The controller does not have a sliding switch to turn it off and on like the standard. Sounds like I have a hybrid. The camera is 4k, so I am confused!
It comes from a reputable source. Just wondering what I have got here?
What make you think that is not a pro/adv rc? Because looking at your pic, it is!
I have a full sized usb on mine. It may be the P3 4K. Does it say professional on the name plate on the phantom?
I have a usb on my advanced controller too which I understand is the same as the P3P
OK - It is the phantom3, 4k. Problem solved. I thought it was the pro as it had 4k, did not realise there were the different models. Thanks everyone.
Was it sold as a Pro? If so you should complain and send it back.
The 4K is worth about half as much as the Pro so you should make sure that you didn't pay too much.
canadiansauna
