Phantom2 vision plus back screen diagnosis
As many others have had issues with a black screen on FPV I've been having the same issue. Tried everything to get it working with no luck. So I thought I would do a test others might find helpful. I suspected my wifi module of overheating so I removed my battery from my drone and put the drone in the freezer for 15 min. Removed and reinstalled the battery and went thru normal power up proceedure and live feed works. Took it outside and flew for 30 minutes and all worked great. Same issue of black screen returned after I brought it in the house and let it warm to room temperature. I'm going to disassemble and add heat sink compound to the inside of my WiFi module. Repeat of chilling made live feed work again! Might be a good test for those suspecting the same
Jerry P
