I've searched until I'm blue in the face and I cannot find a description of what I need to do to install all of this:
Phanton v1.1.1 (Naza M2)
Zenmuse Upgrade Board
Phantom 2 FPV hub
DJI Mini iOSD
Neewer TS-351 5.8GHz TX
SC2000 Camera
I've got most of it figured out. I know I need to replace the main Phantom board with the upgrade board. All of the components are plug and play into the FPV Hub, except the Camera. I don't have the Zenmuse gimbal, and for now just want to use the SC2000 for my FPV camera (I may add the Gimbal, GoPro and a remote video switch later).
The FPV Hub has an 8 pin connector to go from the new upgrade board to the hub, then an 8 pin connector to go to the Zenmuse gimbal. Presumably, I'll need to connect four of those wires to the SC200 instead? Does anyone have a wiring diagram for that?
Or is there a better way for me to be doing this all? Should I dispense with the FPV Hub and connect everything directly. In that case is this the correct wiring? http://www.ravecreative.co.uk/phantom2/avl58-miniIosd-P2-wiring.pdf
Edited. I just realized that wiring diagram above also does not include the camera. Every diagram I've found makes reference to the Zenmuse gimbal. I looking for one that doesn't use the Zenmuse.
Thank you in advance.
Phantom 2 FPV hub
DJI Mini iOSD
SC2000 Camera
