Phantom three pro question
I fly using the DJI app The highest I can set my distance and altitude is 500 m around 1600 feet. Is there someway to bypass this to get more distance. Thanks for any help
Perhaps disable the "enable max distance" setting in the app. That setting is used to limit distance by setting a max up to 500M. If you disable it, there is no max distance set and you can go beyond 500M.
Reactions: ROD PAINTER
And the max altitude of 500m is max you can get ... for any P3 ...
Note that altitude is referenced to the take-off point which is taken as zero. It does not follow rise and fall of terrain.
Nigel
seocompanycalct
