Phantom 4 Windsurfer controller magnetic interference
Lynnwood, WA
I bought a Windsurfer for my P4 from eBay. (see pic) When I put it on and turned on the Controller I immediately got a Magnetic interference error. When I took it off the error went away. I'm too afraid to fly my drone with that error displayed. What gives?
Yes, as a matter of fact I just got my third set today. I am trying different ones to see if one is any better than the other. I never encountered that error message in relationship to the windsurfers.
I have the exact same ones you have case and all. They work great! I use them with my Inspire and all my Phantoms. Never had any problems.
So, how would you rate this item ? Any good ? If yes, can you please provide the link for the purchase. Thx
Sent from my SM-N9208 using Tapatalk
Haven't had a chance to try my new ones yet, maybe today if the wind dies down a bit.
Any update to report on your latest windsurfer experience?
I have used the new copper clam shell ones a few times with good results. They are similar to the other ones as far as distance but the design is superior. It keeps the antennas parallel which I think helps in giving a consistent signal. I am about to go fly a Litchi mission over the ocean about 2.5 miles one way. At least with the Litchi I know it will complete the mission even if I lose signal but it should be interesting to see how the reception is.
Reactions: JesusDisciple
Have you done a battery upgrade? What happens if you lose signal at 2mi out and there's not enough battery for a 5mi mission over the ocean? Have you done similar length missions so you know there's room for wind tolerance?
I've got the same windsurfer, the copper clamshell. Out of the 3 windsurfers I own, I like that one best for storage convenience and aesthetic look. All three of mine seem to work about the same for range.
I have the same Windsurfer. The reflector is made of aluminum, a non-ferrous metal. It has nothing to do with your magnetic interference issue. That message comes from the Phantom not the RC.
CORRECTION: I have the one-piece model (both reflectors are a single rigid unit). Regardless yours is still aluminum.
I bought a Windsurfer for my P4 from eBay. (see pic) When I put it on and turned on the Controller I immediately got a Magnetic interference error. When I took it off the error went away. I'm too afraid to fly my drone with that error displayed. What gives?View attachment 58163
Hi John, sorry I misspoke, it was just under 2 miles one way. I have flown that route a couple of times (without Litchi) just to gauge my battery life. I had to factor in a relatively strong off shore breeze but I returned with just under 50% battery flying at about 14 mph. By the way although the flight is over water, it is a bay so if my battery did start to run low I could abort and land along the coastline somewhere and hopefully be able to find it.
Everything you said about the copper clam shell I agree 100%. Today I was out 10K feet plus and still had 93% reception.
I have the ones that are aluminum, one piece with clips to keep the antennas vertical. Do you think the copper is better?
Michello
