Phantom 4 Pro V2.0 or Phantom 4 Pro+ V2.0
Hi, guys! Wonder which of the two drones is better suited for aerial photography? Whether there will be a problem with seeing the display of Phantom 4 Pro+ V2.0 in sunny weather?
Both are very good and will produce identical results because there is no difference between the aircraft and cameras, just the controllers.
The + model is better for viewing in bright conditions, but it's not hard to find a shady tree or wall to use the non+ version on a sunny day.
If you want to use other apps for mapping missions etc, the + version won't allow you to load those.
The non+ version allows you to use other software and to use a larger screen.
It's your choice.
I have the plus version, and bought a standard remote on eBay for $150 to load my mapping programs on...
I hate using the standard remote with my iPhoneXR it’s so dark compared to the plus monitor.
I have both controllers. The plus doesn’t get used as much as the one with my iPad mini. Too small a screen for me.
I'm with you on that. When you need a toothpick to use your touchscreen, the screen is too small!
hcashmore11
