Phantom 4 Pro replacement ribbon cable
Hi, I need to replace gimbal ribbon cable after crash (camera broken in two peaces).
But comparing my cable to cables available online, there is a difference - there is
additional connector near end of the cable connected to drone body. This little
connector is missing on my cable.
But comparing the cable to my non-Pro drone, there is some electronic component
between two rubber and metal parts holding the camera, where this little connector
is connected.
Are there more Phantom 4 Pro versions ? New cable and old cable is similar
except this small connector that is nowhere to connect.
Do not worry, you can use any of these cables, additional small connector is not use, just isolate it with tape.
I am doing some self repair on my drone and I cannot seen to find any info online about where to start troubleshooting.. when I turn on my p4 pro, the drone does its start up chime the light under the 4 motors flash thru different colors but the little light where you press in to sync or pair with the remote DOES NOT have any light whatsoever, the fan nor the camera donot seen to do anything either..I replaced the camera gimbal board which receives power from the main processor board attached to the drones frame..the single ribbon cable that connects the 2 boards together looks fine, no bends or tears....Can anyone give me there opinion on what it might be that will not make the camera, fan or link link light to work??? I'm thinking something from the main processor board isnt receiving power to pass thru the ribbon cable to power the gimball/camera side??? Any Ideas????Thank you for any input or opinions!
MS60
