Hi everyone,
I'm a relatively new flyer and very new to the Phantom Pro 4+ AC and the DJI GO 4 app. So far, flights have been good, always LOS and under 200'. The AC has performed well, the only problem being me breaking one of the gimbal lock legs when taking it off of the gimbal
...a new one from Polar Pro is on the way.
I plan to use the AC quite often from my sailboat while the boat is underway or at anchor/moored. (My wife and I are full time live aboard cruising sailors.) When launching the AC from the boat, (all launches will be by hand and landings will be hand catches), when do I set the Home Point to be the location of the RC...prior to launch, or after launch while the AC hovers?
When practicing in the field I've been flying, I've had to set the RC as Home Point after the AC launches and hovers and the app announces "Home Point has been set, please check the map." I then reset the Home Point as the RC, then move a fair distance away, 100' or so, from the launch location while flying. In these instances, when I initiate a RTH, the AC has always landed about 5 feet in front of where I am with the RC. So that's good.
However, when I've set the RC as the Home Point prior to takeoff, the Home Point seems to reset as the GPS launch location once the AC is in the air. Am I missing something on setting and keeping the RC as the Home Point prior to takeoff? Not paying attention to this could be bad if we sail away from the launch location and a RTH initiates with the launch location as the Home Point!
Thanks!
Thanks!
