Phantom 4 Pro+ Flight Data no map no satellite
On my Phantom 4 Pro+ controller, if I click on flight data (the list of flights) and click on a flight, it shows me the path of the flights and where photos are taken, but it doesn't have any map background. It also doesn't have any satellite background if I choose satellite from the map-satellite-night selection and if I select night it's just all gray with no map either. So it makes it not much use.
I sometimes found it interesting to use this on my ipad when I was flying a phantom3 to take a look at where I'd just flown or where a photo was taken after the fact.
(I had the map no-satellite map issue on the real time map used when flying but solved that for the map used while flying several months ago but I don't think the flight data map used for reviewing flights has ever worked on my Pro+ controller.)
Are others getting this too no the Pro+ controller? Is there a fix? Many thanks.
Hi there ! You will have to reboot your remote to factory settings. The map should update after.
hcashmore11
