Phantom 4 Pro and horizon/sky pictures
I had a Phantom 4 Pro that took great horizon pictures. Now that I’ve upgraded to a Phantom 4 Pro, any horizon pictures I take are overpowered by the sky and the ground looks dark. The picture I’ve attached is an example. Shooting in Auto at 100 iso with an ND8 filter. Any ideas how to correct this?
If you shoot an image with a large area of bright sky and a smaller area of dark foreground, the camera exposure metering has a problem dealing with the difference in brightness from the two major elemants.
Left to make the decision itself, the camera will expose for an average of the scene which will be unsatisfactory all round.
Some solutions could be to either:
  • Expose for what you want to be the subject rather than the average of the whole frame.
  • Bring up shadow detail and/or reduce highlights in your post processing
  • Compose for a more evenly lit scene
Is there any particular reason you were using the ND filter?
In stills photography, all it will do is lower the light level and force you to have a slower shutter speed.
Unless you want to shoot with a slower shutter speed, there's no reason to be using an ND filter in stills photography from a drone.
Reactions: ravedog
I’ll try removing the filter and shoot again. Should I use the filter for video?
Some people like to use the ND filter to get a slower shutter speed and get a small amount of motion blur for video.
It's not essential and many don't use it at all.
But it's useless for stills unless you have a particular reason for wanting to slow the shutter speed down (and that would be quite unusual).
Another option is to take three or five AEB shots and then combine them with software that can do HDR rendering. I use photoshop.
For a picture like that one with a clear demarcation between light and dark you may only need to layer two versions over each other and then mask out the top or bottom half. In other words take two exposures: one exposed for the sky, the other for the ground. Then layer them in photoshop (for example) and of the one with the overexposed sky is on top then paint a mask on the sky to let the sky from the layer below show through.
Thanks for the help. Appreciate it.
hcashmore11
