- Joined
- Mar 7, 2017
- Messages
- 1
- Reaction score
- 0
- Age
- 26
Hello all,
I've been searching only for a few days trying to find an answer to my problem but haven't found any posts that match up to my issue.
I crashed my DJI Phantom 3 Standard a few days ago. The gimbal disconnected at the middle (roll) motor and the flat cable ripped. I did a flat cable replacement myself, and the gimbal and camera now function normally.
However, I noticed immediately after the crash that there is a hissing noise coming from the gimbal. The roll motor was disconnected when I noticed the sound, so I can rule out the bottom motor and the camera as the source of the noise. Disconnecting the entire gimbal from the aircraft body also eliminated the noise, so I know for a fact that the noise is coming from the gimbal and not the UAV's internals.
Here's a video of the noise from the gimbal:
side note: The gimbal assembly is currently attached with a nut and bolt. This is just temporary so I don't waste the plastic discs if I have to remove the entire assembly again.
Do you believe I can ignore this noise, or is it something which needs to be addressed?
Thanks!
Thanks!
