Phantom 3 Pro wont bind.
Two controllers won't bind to Phantom 3P. Tried the manual method. Nothing.
Can't find any apps or downloads for it either. Thanks
Have to go to DJI Downloads for firmware. Seems you may have a mismatch, provided they are the correct model remotes for P3P
I have several P3s I use to pull a line up and over then draw a safety line when I work high. Recently I bought a P3s from a friend who was assigned overseas. His P3s was left idle for a year or so now the aircraft will not link to the controller. It is as new flown only a couple times, then left in storage for over a year. Now the aircraft will not recognize any 3 P3s controller I have. However, controller will link to my other P3s with no problem. I don't know but assume the aircraft may lose its configuration over time. Similar to a computer left idle if the main board battery goes dead in storage. Nothing I have tried has worked so far, I didn't pay much for the P3s so may just hold for parts. I like the P3s because its a good lifter it lifts my safety lines up easily.
AlienzEyes
