Phantom 3 Battery
Power up as though you are going to fly ... that's the P3, Controller and Phone / Tablet.
In GO - you should be showing the video playback from camera.
1. Tap the three dots three lines menu up in far right top corner.
2. Tap the 4th item down the list that shows looks like a Battery with a triangle
3. You should now have the Cells displayed, Low Battery and Critical battery warning settings etc.
4. Tap the ADVANCED SETTINGS > to get to next battery screen.
Set to desired auto discharge time ... I suggest for most people 2 - 3 days should be fine.
Exit menu ... exit and do this for each battery you have. Unfortunately there is no way to interact direct with the battery. It has to be done via GO.
Reactions: Allan8056
No prob ...
If you look in the battery setting on the GO app then you should see it. It is at the top of the display and it says discharge time. Mine is set for four days
Its already answered ....
