I'm trying to update my aircraft firmware to the latest revision which, from the DJI website, I understand to be
P3A_FW_V01.11.0020.bin. This is the filename I see in the download folder on the PC after clicking on the DJI firmware website link.
As I understand it, if you have an SD card to USB adapter, the procedure should be fairly simple, but
I can't get the aircraft firmware upgrade to work. Here's what I've done.
1) Removed SD card from aircraft and formatted it without incident.
2) Copied P3A_FW_V01.11.0020.bin to the root directory of the SD card. Since the file extension is .bin,
I presume no unzipping is required.
3) Insert SD card into aircraft
4) Power up aircraft. Now here's where things begin to get fuzzy because there are numerous
descriptions about how you know that the FW update is done (e.g., sounds, light indicators, wait some
period of time), but they don't seem to agree with each other, nor are they always clear. Anyway,
after this step you should be able to...
5) Power down aircraft, remove SD card, and look at the contents on the PC via the USB adaptor. There
is a new text file present, and I've included the listing below. If you look, you see repeated upgrade
attempts with two different FW versions. Some attempts are successful, and some aren't. Frankly,
it doesn't make sense. A commenter offered that since I saw a successful status near the bottom
of the log file, it might have worked. WhenI just move on to the next step to the controller upgrade
which I understand to be...
6) Plug USB adapter with SD card into rear USB port of controller. Light on bottom from edge should
turn from red to blue (while upgrading) to green (when linked).
Have I got that right? Any insights? Thanks.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.10.0090.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
Result: Abort.
========== 2017.01.01 12:13:57 =====================
Result: Abort.
Result: Abort.
========== 2017.01.15 11:38:41 =====================
Result: Abort.
========== 2017.01.21 15:34:48 =====================
Result: Abort.
========== 2017.01.24 20:08:36 =====================
Result: Abort.
========== 2017.01.29 13:43:53 =====================
Result: Abort.
Result: Abort.
========== 2017.02.03 15:08:19 =====================
Result: Abort.
========== 2017.02.05 12:57:04 =====================
Result: Abort.
Result: Abort.
Result: Abort.
========== 2017.02.19 15:55:06 =====================
Result: Abort.
========== 2017.04.16 09:49:56 =====================
Result: Abort.
========== 2014.01.01 00:00:09 remo-con disconnect======
Result: Abort.
Result: Abort.
========== 2017.06.17 15:16:16 =====================
Result: Abort.
========== 2017.06.17 15:46:08 =====================
Result: Abort.
========== 2017.06.23 15:28:32 =====================
Result: Abort.
========== 2017.06.24 16:03:38 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Packet: P3S_FW_V01.11.0020.bin
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
