I've received a lot of PM"s requesting a complete parts list with links to purchase everything to do the WIFI mods.
One problem is that for a lot of it I used what I already had on hand. I can list the parts, but not necessarily where I got them (I just had them left over from previous projects.)
The amplifier is RadioLabs:
http://www.radiolabs.com/products/wirel ... -800mw.php
The Antenna (as previously mentioned) is Circular Wireless SPW24 :
http://www.readymaderc.com/store/index. ... ts_id=1096
The repeater antenna (matched to the SPW24) is the HELIAXIAL24 :
http://www.readymaderc.com/store/index. ... ts_id=1538
The cable coming out of the camera (I've now removed the extension cable) is 8" of this :
http://www.ebay.com/itm/RG178-U-fl-IPX- ... 1e840cf4c9
The attenuator is 6db :
http://www.ebay.com/itm/SMA-2W-male-to- ... 4d0adce5c3
The connector from the attenuator to the amp is a 90 degree SMA to RP-SMA that I had.
The cable from the amp to the antenna is RG316 RP-SMA to SMA that I had, but pretty sure I got it from wifiexperts (see link for cable out of camera above).
The connector holding the antenna to the landing gear is a standard cable tie that I had.
Originally I used a separate battery (I already had) to power the amp but it's this :
http://www.ebay.com/itm/Turnigy-1000mAh ... 27dd747a00
I have a bunch of BEC's lying around, but in the latest go around I used some crazy small one's :
http://www.ebay.com/itm/131035992771?ss ... 1497.l2649
All the power connectors are standard JST that I had laying around.
I soldered to the battery terminal (see picture above) drilled and filed the hole to the size of the JST connector and epoxied the JST connector in place.
I think that about covers it.
edit: Some are asking about the quick release on the repeater / heliaxial :
http://www.amazon.com/dp/B001FSZUX8/ref ... _ST1_dp_i1
Happy mod'ing.
