Phantom 2 FPV problem
Hello guys,
I have a problem with my fpv setup. I have boscam rx-lcd5802 with built in dual receiver and Immersion 5.8ghz 600mw in iOsd mini.
There are some signal interference between the monitor and the transmitter.
Here is the video of the problem: http://youtu.be/QrSQ7ygTIGU
Do you have any idea where is the problem?
pucho said:
Hello guys,
Make sure both your Tx and Rx are on the same channel. Move the setup outside where there is no other interference. Other than that I cant make any more suggestions.
thongbong said:
pucho said:
Hello guys,
They are on the same channel, i went outside and its the same
pucho said:
thongbong said:
pucho said:
Hello guys,
Where did you get the ImmersionRC? Make sure that its authentic and not a knockoff. Check the back of the Tx and make sure there arent any bad solder points. Check this thread out.
http://fpvlab.com/forums/showthread.php ... r-V2/page3
I bought it from my local dealer, I have checked the back and the solder points are perfect
Did you make sure you were on the correct group as well as channel on the reciever? I believe you need to be on group D for the frequencies to match up with the immerson rc frequencies.
Yes ist the D group, for me channel 7 I think
That definately looks mistuned. Have you tried changing the transmitter to some other channels? You'll find that it's better on some more than others.
I would start right in the beginning and try each one in turn, find which one works best for you
Wouldn't this be related to known issue of compatibility between Boscam and ImmersionRC stuff???
Scav8tor
