Phantom 2 battery isnt charging
Hello,
I go to plug my battery in and it doesn't charge, no lights come on like they're supposed to. The battery still works when plugged into the drone so do i need to replace the charger?
There is a light on the power supply box.
Is this a P2 battery or a P2V battery? On a P2V, there is a way to "force" the charge which works most of the time. After plugging everything, turn on the battery.
Hope this helps.
In a P4 if you have something like 80% battery life the lights on the battery will not come on when you plug in the charger because the battery will not accept a charge. It is not recommended to top off a almost fully charged battery. Check at what % your battery is now, if high, then fly to bring it down ( or just turn on your bird ) and try again.
tpren3
