- Joined
- Jun 18, 2016
- Messages
- 6
- Reaction score
- 0
- Age
- 42
Hi everyone,
I bought a used 1.1.1 off of eBay and I'm having some troubles with it. Whenever I power it on it completes the warm up and then I get the slow flashing yellow light sequence, I think this means it is ATTI mode due to no gps signal??
The rotors will spin up and I can take off but the Phantom is super hard to control and the fails age doesn't seem to function.
I've connected it up to the assistant software which is a pain as the USB cable connection isn't good and requires moving into a certain position to be recognized.
It wanted to upgrade the firmware. I did that and I imported the default settings. I did the TX calibration and the Advanced Call calibration.
Everything looks good except for:
1. Gps hardware shows all dots, like ....
2. Compass values are always 0
3. I can't check the IOC option, it says gps needed but I'm in the house and not getting a signal.
4. I can't get it into compass calibration mode using the TX
Any ideas on what might be up? Could my gps and compass both be bad? Would you recommend I open and check all the connections?
Thanks.
Thanks.
