Phantom 1.1.1 Flight Issues
Discussion in 'Phantom 1 Help' started by Andrew Reynolds, Jun 18, 2016.
  1. Andrew Reynolds
    Hi everyone,
    I bought a used 1.1.1 off of eBay and I'm having some troubles with it. Whenever I power it on it completes the warm up and then I get the slow flashing yellow light sequence, I think this means it is ATTI mode due to no gps signal??
    The rotors will spin up and I can take off but the Phantom is super hard to control and the fails age doesn't seem to function.
    I've connected it up to the assistant software which is a pain as the USB cable connection isn't good and requires moving into a certain position to be recognized.
    It wanted to upgrade the firmware. I did that and I imported the default settings. I did the TX calibration and the Advanced Call calibration.
    Everything looks good except for:
    1. Gps hardware shows all dots, like ....
    2. Compass values are always 0
    3. I can't check the IOC option, it says gps needed but I'm in the house and not getting a signal.
    4. I can't get it into compass calibration mode using the TX
    Any ideas on what might be up? Could my gps and compass both be bad? Would you recommend I open and check all the connections?
    Thanks.
    #1 Andrew Reynolds, Jun 18, 2016
  2. MauTech
    Yeah sounds like a connection might be switched or a cable isn't plugged in, I'd open it up careful tho, the GPS module cable will only allow you to partially open it, you can unplug that just plug it back in when done
    Andrew Reynolds likes this.
  3. Andrew Reynolds
    Hi,
    Thanks for the suggestions - I'll see about taking it apart today...
    I just had it outside with the computer and assistant software hooked up... I've attached a couple of screenshots to show the no gps / all 0s on the compass
  4. Andrew Reynolds
    OK looks like we are in business... I took the upper plastic off, I unplugged and replugged all the connections. I put the whole thing together and powered it up then I got a yellow / red flashing sequence. I connected it up to the Assistant software and finally started getting readings from the compass / GPS (yay) I went ahead and restored default parameters and did a basic calibration then I took it outside and went through the compass calibration sequence. I then got a flashing green and was able to take off and land pretty easily.
    Because I like to live dangerously I decided to turn off the controller and see what happened... I'm guess my GPS signal wasn't great because it shot up and tried to land on the roof of my house - as it came down I grab it and clipped a blade on the gutter - it then wouldn't spin up but after a full cycle it seems fine.
    Thanks for the help on this one - I'll go find a bigger space to play in... the one question I do have is I noticed that the thread on one of the motors isn't great... it was a really pain to get the blade off / on. The blade is on tight and it doesn't seem to affect performance so should I be concerned?
  5. rattydude77
    liverpool ny
    If the prop/blade isn't chipped or anything I wouldn't bother but if you can get the prop of see if you can put a new one on it when needed if not youll have to replace the motor and depends on what motor there different types clock wise and counter clock wise /cw/ccw
  6. magicman
    I have the same problem as above. I have tried the above but nothing has worked.. Any other ideas??
  7. rattydude77
    liverpool ny
    Are you having a hard time hooking up to the naza software
  8. magicman
    None at all.everything looks good and runs good. Just no gps signal
  9. rattydude77
    liverpool ny
    Have you hade the phantom apart if so make sure its still pluged in
  10. magicman
    I have checked all the plugs many of times. The guy i bought it from said it was a new compass. Could that be bad and cause this? Would the light still be just flashing yellow? I check the gps plate and it looks good no cracks..Is there a way to check it the compass?
  11. rattydude77
    liverpool ny
    Not sure how to check other than looking at it you have the phantom 1.1.1 right for the hell of it open the battery door and press the little red button on the right top its to bond the remote to the phantom and let us know good luck
  12. magicman
    Rattydude77, thanks for the fast response and help. Im not sure if its the phantom 1.1.1.when i turn the remote off a red light comes on but i don't think there is a button to push. I will have to double check when i get back home. I don't remember see a button.
  13. magicman
    Would i still need to do that if the Tx its working.. I am able to fry i just have a flashing yellow and no gps?
  14. rattydude77
    liverpool ny
    If you google dji phantom 1.1.1 yellow flashing lights it tells you to do it check it out google will b your friend lol
  15. magicman
    Well.. Tried everything again.. Rebond the tx, checked all wires, no clue what to do next.. I flew it with 3 batteries but it sucks with no gps.. Anymore ideas would be great. Not sure if i should try a new compass or gps next??
  16. Andrew Reynolds
    For me it was super easy sorry... As soon as I unplugged and replugged the leads for the NAZA the GPS started functioning as expected and the drone worked just fine. I did look into new GPS and Compasses modules and they come up on eBay / Amazon all the time for decent prices.
    If you aren't getting anything in the computer software then I would guess at least the GPS needs replacing, if not both - sorry I can't be more help.
    Good luck!
  17. magicman
    Thanks, i ordered a new compass. Going the cheaper way first. I hope that's it
  18. magicman
    New compass didnt work.. Any other help would be awesome. The Naza reading for the compass shows 0.0.0
  19. rattydude77
    liverpool ny
    Try taking a magnet and circle the compass
  20. rattydude77
    liverpool ny
Similar Threads - Phantom Flight Issues Forum Date
Out of new box Phantom 2 w/H3-3D Flight issues Zenmuse H3-3D/H4-3D GoPro Gimbal Sep 8, 2014
Check out my 6 mile round trip flight with my Phantom 4 in 11 degree weather . Editing (Photo and Video) Jan 8, 2018
Phantom 4 lost power mid flight Canada Jan 7, 2018
verifiable highest from ground Phantom flight...? General Discussion Jan 1, 2018
Phantom 4, 2nd flight, some questions General Discussion Dec 27, 2017
