The DJI Go version (pre P4) does not support the pano mode. Litchi and the P3 will do just fine, especially when you add the 4K.I just purchased a P3 4K. I realize this is the P4P discussion but I know a lot of you use Litchi. The question is should I use Litchi for panorama photography. Not sure if DJI Go has this option.
Thank you.
If you want the best quality pano, manually take a bunch of pictures, with some overlap, and stitch them with Microsoft ICE.I just purchased a P3 4K. I realize this is the P4P discussion but I know a lot of you use Litchi. The question is should I use Litchi for panorama photography. Not sure if DJI Go has this option.
Thank you.
Manually taking shots will work fine if you have a simple single row pano but as soon as you start getting into multirow panos it becomes way more difficult and that’s where software that automates the process, like Litchi works very well.If you want the best quality pano, manually take a bunch of pictures, with some overlap, and stitch them with Microsoft ICE.
Microsoft ICE does very good with multirow panoramas. In fact that is what it is for! It is easy to use but it has powerful manual features as well. Best of all it's free! Take a look at a 2 row panorama with 4 pics in each that I took and proceeded in Microsoft ICE. (8 pictures total, created 50 megapixel image):Manually taking shots will work fine if you have a simple single row pano but as soon as you start getting into multirow panos it becomes way more difficult and that’s where software that automates the process, like Litchi works very well.
Nice pano. I usually take equirectangular panos (spherical) and use PTGui and photoshop for simpler ones. ICE is Windows only whereas the others are multiplatform.Microsoft ICE does very good with multirow panoramas. In fact that is what it is for! It is easy to use but it has powerful manual features as well. Best of all it's free! Take a look at a 2 row panorama with 4 pics in each that I took and proceeded in Microsoft ICE. (8 pictures total, created 50 megapixel image):
Those are all good programs, just sayin what my favorite is. No good if you're a Mac user, but I'm a windows guy myself... Hence my choice of software. What OS do you use?Nice pano. I usually take equirectangular panos (spherical) and use PTGui and photoshop for simpler ones. ICE is Windows only whereas the others are multiplatform.
Yup, I was thinking more of other video applications for the 4K. Should have been more clear. Thanks for pointing that out!4K is for video so it will have no effect on stills taken in pano mode. You can extract images from the 4K video and they may be better than the regular stills but I highly doubt the OP would be using the 4K extracted stills for a pano.
Regardless, Litchi works great for panos and adds so many more features than DJI GO.
Chris
Litchi panorama mode works with all versions of P3. The problem is that panorama mode only works in “s” or “a” mode, which leads to excessive drift. Still takes surprisingly good panoramas except the drift can carry you into obstacles. Litchi works better with the P4 as it allows the app to work in FPV mode, where there is no drift.I just purchased a P3 4K. I realize this is the P4P discussion but I know a lot of you use Litchi. The question is should I use Litchi for panorama photography. Not sure if DJI Go has this option.
Thank you.
Thank you.
