Hi there guys, hoping someone has some sensible input on this... flying P4P in 15mph gusting to 25mph winds... windy but not too much... the drone has around 200 plus flights on it and have flown in worse... however the only thing I can think of is that it was hit by some kind of swirling wind... So I was hovering at 50 meters after flying for around 17 minutes... when all of a sudden the camera goes into gimbal over limit and hangs loose so I cannot see clearly what is happening.... I put in no stick commands hoping it is a gust and will come back.... then the drone just falls from the sky at 10m/s (thats a free fall?) I am looking at the screen and did not see what the drone looked like as it fell... it was literally over in seconds.. as you can see.... so I go and find the drone and luckily it had a soft landing in a bush and is fine.....
Looking at the data it gave a motor speed error as it fell... compass errors and that the compass had changed direction too much in a fraction of a second... this is what made me initially think a propellor had come off. But when I found the drone, it is all ok... and the weird thing is, it works perfectly and flies perfectly now... Also it was running at maximum amps as it fell something like 24amps? Its very strange.
So.... is there something wrong with the drone, or did I get hit by a freak wind? I have flown it again now around 15 times without issue.
www.phantomhelp.com
And log is here
DJI Flight Log Viewer | Phantom Help
Upload and view flight logs from your DJI drones
And log is here
