P4P calibration, how do i calibrate the P4P ,
I cannot seem to calibrate the compass on the P4P app, with the P3 once in the app it would have Calibrate beside compass, but the P4P only says compass . how do i calibrate ,thanks
P3s usually required a fan. Not sure if the same applies to P4s.
Is there any reason you are wanting to calibrate the compass?
Normally, it would only be required after rebuilding the drone or modifying it.
If it's flying normally, there is nothing to be gained from recalibrating the compass.
If you need to, here is where you do it.
That's only for recalibrating the IMU
hcashmore11
