P4 Range ??
What kind of REAL WORLD range can I expect with a P4.
Is the range better or worse than a P3 Professional ??
I would say that it's pretty similar to the P3A or P3P. Between 1-2 miles in Europe, almost twice as much everywhere else. There is at least a dozen of factors that will afffect the actual experienced range, the most obvious being direct line of sight, antenna positioning and wifi congestion, but also some less obvious parameters, like air humidity and subtype of remote controller.
2.2miles CE in the uk, supposed to be 3.1miles FCC, a lot depends on the terrain and whether line of sight rather than flying away over trees. best to move yourself to give the least flight distance and keep the power up
just posted a bit on the spark forum about the quoted distances with the new controller
I've been out 10,000 ft in the US with jungle between me and the AC. That was about 400 ft altitude. The higher you go the farther you can go to a certain extent.
finestheatingn
