I got thru that issue, and I updated remote and the drone and everything checked out ok, Then I put another battery in the drone and it has a warning "battery failed authentication" and will not let me fly. The battery that I used during backup works fine, but my three spares will not. Any ideas????I'm glad things worked out for everyone else that had the same 99% stall issue and was able to resolve it. I have to give full credit to @JohnnyD913, I was in the same situation until he braved an hour on the phone with DJI to figure out the solution.
Based on what I've read here, looks like you also have to update those non working batteries. The one that worked, updated correctly. Just re-do the same process as you did with the working battery.I got thru that issue, and I updated remote and the drone and everything checked out ok, Then I put another battery in the drone and it has a warning "battery failed authentication" and will not let me fly. The battery that I used during backup works fine, but my three spares will not. Any ideas????
HELLOOOOOO! I must be missing something here......are is it everybody else in this conversation? I attempted to use the DJI GO4 app to update my P4 and it pops up a notice stating that doing the update, my aircraft will be limited to a height of 30 m and distance of 50 m!!! I then had a choice to Accept or Cancel. This was a NO-BRAINER! Why would Anybody want to do the update???
So did a little test flight yesterday evening, and everything went fine, but i was getting and "IMU Error: Calibrate IMU", which seemed odd, bc i calibrated it already. so i restarted the bird, which was sitting on a picnic table, and the same error appeared way with all 4 LEDs lit up red. I moved the bird to the ground, and then restarted it again, and it gave me the error again, but then it went away and gave me the good to go......not sure if this is some sort of bug or not....has anyone else seen this behavior after the firmware upgrade???
Even with only flying with Litchi? And who would Ever want to limit their flights to to 50 meters when it can fly 3.2 Miles?Because a week later you'll find that the app will update and then you'll have no choice but to update
