RTH works fine on signal loss with Litchi. I use it all of the time. Just don't loose the signal if you are using the following flight modes: VR with Immersive/Joystick Head Tracking active, Follow, Focus and Track. But these flight modes are pretty much worthless without a signal anyway.Those using Tracking with Litchi - make sure you read carefully the Litchi warnings -
When doing some operations like Tracking on Litchi - Return To Home when signal lost may not work on P3S (fine on most the other dji drones). I think it will only hover instead then land when battery out - not good if over water - I nearly lost my P3S this way.
... Just don't loose the signal if you are using the following flight modes: VR with Immersive/Joystick Head Tracking active, Follow, Focus and Track.
Best $350 bucks I've ever spent.
I found a nice cheap case to go with it:
PIPELINE 100% Aluminum Case for DJI Phantom 4 and Phantom 3 Drone | eBay
She's not dainty, but I can fit all my gear and more . . .E]
Couple of questions on the case:
1) Does it fit your Phantom with the props on?
2) Did you have to modify the foam to get your P3S to fit? The description on Ebay states that it is designed for P4 and some modification may be necessary for P3. Just wondering if you had to modify it, or if it was a good default right away?
Thanks!
I paid $24.99 for mine at the Google Play store last month.Did you guys all purchase the Litchi app for $22.99? Sorry if it was a very obvious question!![]()
What are the REAL benefits of litchi? I have read about some of the follow me features and mainly the waypoints which you can map out rather then fly the drone to set the points. What makes it a better option than using DJI GO?
I really wasn't going to spend any additional money on my PS3 as I got it just to try a "real" drone for $314 refurb on sale at NewEgg. It is a lot more drone than I expected, so I just added a case similar to the one in this thread, a Surfer, a new phone holder (the one that came with it slipped after I tightened it and I almost lost a $500 phone), some extra props and quick connect prop guards. Now except for a second battery I'm set for the next year or two I think. The Refurb PS3 is IMHO the best intro to drones you can currently can get price/performance wise.
Can you still get the $349 deal.
