P3P tilt and more
Hi Folks
I've noticed the dreaded tilted horizon issue on my P3P, after updating the firmware. I should add though: didn't turn on the bird / take off from a completely level surface. Also, I'd been fiddling with gain/expo settings. Finally, I flew with a battery that wasn't upgraded yet (doubt that this means anything, though).
Still consider myself a newbie, so I'm not sure which of the (many) suggestions to try out, hmmm?
And a quickie:
How do I know/pick which of the 3 gimbal configs are used, when flying?
Thanks, kind regards,
Mike
If you go into settings on the dji go app when connected to the drone , goto camera icon and there is options the re calibrate the gimbal or there is an option to calibrate the tilt manually in there , try that
Reactions: JoBe
DonT
