P3A vibration
Hi! Just got my new phantom.
Bought it slightly used (Charged 8 times)
I was wondering, is it normal, if i turn engines on and hold finger against, it has small vibration.
With props on it doesn’t shake at all.
Only when hovering and warming in cold weather . (then is vibration very hard)
Vibrating about 30 -60 sek and then phantom is warm and stabile again...
Is it all OK?
And sorry about my language (Hope it was understandable) :)
Your language is OK......check to see IF any props are chipped scratched OR damaged in any way ! look at them top sides and bottom sides !...sure confused as you why the drone is subject to hot n cold !
IF you are able....attach a short video....That will sure help to diagnose the problem.
Yep , props have very minor scratches, but indoor they run very well and outside wobble only if minus degrees celsius and about 1 min. Small vibration without props is only if put finger against the engine (cant see on video) do you have it too?
Changed gain settings to 80 (pitch, roll and yaw) Now its okay in cold too :) no vibration at all .
Seems like small motor vibration doesn’t disturb the drone at all. All good and enjoying my phantom now ..
shimuafeni fredrik
